[SOLD] PCE SB LA 1.5 ratio aluminum rocker arm setup with Comp Cams pushrods
physixx
Edison, NJ
I have for sale a set of SB LA Performance Engine Parts aluminum roller rockers, shafts, hold down hardware, spacers, shims and ball/cup pushrods for hydraulic lifter application. The rocker arm kit is P/N PCE 261-1031 and is the 1.5 ratio rocker with a shaft diameter of .875”.
Speedmaster PCE261-1031 Procomp Electronics Roller Rocker Arms | Summit Racing
The pushrods are Comp Cams P/N 7821-16 and measure 7.389” long, 5/16” in diameter.
COMP Cams 7821-16 COMP Cams High Energy Pushrods | Summit Racing
These parts were in an engine with very little running time. It seems that the valve spring diameter was a bit too wide and the inside of the rockers were rubbing on the springs on a few of them even though they are advertised as fitting the 1.5” diameter springs. No problems with any strength being compromised as they didn’t rub that much and for very long. A little massaging and they are good to go. The outside edge of the end attaching blocks needed to be ground for clearance of the Edelbrock cast aluminum valve covers. I would like to get $275 for everything plus the shipping.
Ken
Edison, NJ
