PCV on Holley HP Carb.
Mopar Tim
vista CA.
What do you guys think is the best way to implement a PCV valve on this carb/
Holley 0-80803HB Ultra HP Gas 750 CFM 4 Barrel Carburetor.
With this intake
you can drill and tap for a threaded nipple in center of spacer or intake if not can buy one Ebay
RPC Open Spacer 4150 4160 Holley Carburetor 1" PCV Fitting Studs & Gaskets
There appears to be a boss at the rear center of the carburetor base plate. I would drill and tap that for a PCV nipple. Problem solved.
I run that intake, 1" spacer and a drop base 14" air cleaner.
If you can, tap a small hole through the boss as Rusty suggest or find a 1/2-1" spacer with a vacuum nipple.
You could always put a nipple in the hole on the intake #8 port for the hose to connect to if you don't have an outlet near the carb base... Stock power brakes used a similar location on the #5/#7 ports for the power booster...
