i have a small block with 10" of vacuum.breather on one side,pcv on the other.my question is under load or full throttle there is little to no vacuum.how does the engine get rid of blow by?would i benefit running a hose from the breather on the valve cover to the base of the air cleaner,so it would pull pressure from rings into the carb??or a hose from the pcv to the base of air cleaner??
