Well I have a 65 225 charger slant six. Balanced blue printed. 40 over piston 10to 1 flat tops. Block decked 15k the head was decked 110k. The head was ported and polished. I had the biggest valve put in it that would fit... dont know the size. I had a strong cam put in it custom ground from Erson cams. Roller rockers from T and D. Clifford performance kit with 500cfm 2 bbl weber carb. The kit comes with carb intake headers, fuel regulator. true 2.5 dual exhaust with cherry bomb vortex mufflers. 48k volts MSD coil with NGK plugs.Thanks for posting and replying ... That is EXACTLY the sound I'm aiming for. Can you tell me what your engine and drivetrain build spec is? That sounds like our friend's '69 Roadrunner and I didn't think I could attain that sound out of a /6 ... Very encouraging!!
