It can affect both, but most people only notice the net lift numbers. If it has the correct net lift, the geometry must be right, right????? ......Nope!That's what I figured. Having the geometry off compounds area lost but doesn't really change net loss.
Did I get that correct?
Yea! chocolate ! Toco bell after heavy drinking, viagra in one doseage (10 hour stiffies!)I didn't think this was true until I took Multi-variable and Vector Calculus. Perhaps there IS such thing as too much of a good thing.
Yes, that’s good to know. Thanks. By the way, the Harland Sharp tech said they make their 1.6 closer to 1.7 to account for that.So for the OP...did you want to know the loss of lift due just to the lifter angle?
I think your decimal is in the wrong place. I'm seeing a difference of 0.016" for the roller rocker from shortest to longest pushrod.Or how p'rod length affects lift...
A whopping difference of 0.165" in total valve lift for the same roller rocker...just from changing p'rod length.
Honestly, I'd just say run the strongest components you can afford and don't overthink it.
If you're really worried about that 30 thou, just go one size up in the cam.
Next time you're looking at a ruler look how small the 1/32 increment is. I'm not saying it doesn't make a difference in flow and/or power output, but honestly it probably wouldn't be much.
Yeah and a handful of tests out there support this also. It's a bit counterintuitive but at least in some cases the extra lift doesn't do anything at all.Agree.
I have 1.5 Harland Sharp rockers and a smallish cam for what I have.
I asked Dwayne if it was worthwhile to put 1.6 rockers on, and he said unlikely to be worth doing, so I didn’t.
Ah, a closet mathematician. I always liked math. I used it a lot for most of my adult life. I think it is hilarious when I see people with T-shirts that say something like "ANOTHER DAY WITHOUT USING ALGEBRA"To get a close number:
- Take the cosine of the AVERAGE pushrod to lifter angle through the lift range
- multiply by the lift at the lifter
- then subtract that number from the lift at the lifter.
Example for a peak lift :
- If the AVERAGE pushrod to lifter angle through the lift range is 14 degrees, then cosine(14*) = .9703
- Multiply by the lift at the lifter: .9703 * .300" = .2911"
- Loss of lift at top of pushrod = .300 - .2911 = .0089"
The above is ONLY for the pushrod-to-lifter angle loss.
Edit to add: For the loss of lift at the valve, multiply the above by the rocker ratio. In this example, where the valve lift is nominally .450", the loss at the valve would be 1.5 * .0089" = .0134". Of course, that assumes the rocker is a true 1.5 ratio.....
As the lift increases, the pushrod to lifter angle increases and that increases the % loss of lift due to the cosine function. So, to be more accurate, you could measure the angle for each 1/3 or 1/4 of the lift range and compute the loss of lift for each range and add them up.
Measuring at the valve tip and working backwards to get this number is not accurate, since there is another loss in lift due to the lift variations inherent in the rocker angles as they move through their range.
Here is an interesting history of why the lifter bank angle ended up where it did in the LA: http://www.cranecams.com/pdf-tech-tips/chrysler-sm-block152-153.pdf
A lot of that is also the parameters of the test engine and the cylinder heads. What Rich showed was really good IMO and probably saved a lot of guys some money. But it is not always the case.Yeah and a handful of tests out there support this also. It's a bit counterintuitive but at least in some cases the extra lift doesn't do anything at all.
Everybody's favorite dude Richard holdener did a 5.3 test with a BTR cam one was rated for stock springs and the other one higher lift and required spring upgrade. Otherwise basically the same cam timing events. Guess what....Just about zero....nada.... difference between the two in terms of power output.
Much of it is in how the cylinder head flows and where it stops flowing more at higher and higher lifts. Also small duration cams really don’t allow much time for air to get in. So if the extra lift is there and the time is short with not so great flowing ports beyond what cam number 1 lifted to, then there really is no point of f getting the high lift cam.
IMO, I like to take advantage of the cylinder heads flow capability. Not so much for the daily driver or mild hot rod, but more so for the heavy street hitter or race car.
See any gain?My home ported J iron heads peaked at 260 cfm at 500 and didn’t increase from there. I wanted all of it so I went to 1.6 rockers to get me to 500. Cam is 280 duration, I believe 234 at 50.
New build, don’t know what I’ll get.See any gain?
