You can also toy around with your launch rpm , and shift rpm til you find the best spot for your combo
Oh,oh,oh,oh ,what a feeling ...It always makes you feel good when you make some changes and it helps out, Doesn't it?
Sorry ,your right about the thread thing and the heat range.The threads on the plug are about 1 1/2 or 2 down,so i guess im good.The mark on the hook is right on the 90 .I think this means the timing is good .Is it right on the elbow of the hook ? Its more to the top of the bend than the bottom ,but its on the bend ...the heat range is on the threads of the plug...the hook is used for timing. 2-3 threads on the plug means good heat range....4-5-6 means too hot and none means too cold
That was the one.It was way over attended .Over 230 cars and only got a couple of runs in cuz of it...wish I would have seen this post. Is that at MOKAN dragway? That is my home track 13 miles from my house. sorry I missed out.![]()
you might have to rejet the carb now woth the pan on itI ditched the mechanical fuel pump and am just using the Holley Blue now.I also made a ghetto sealed scoop pan for the air horn on the Demon.It can draw nothing but outside air now .I hope this stuff helps my Dart in Missouri in a few weeks.Its a 1/4 mile track and maybe some pressurised cooler air will help me into 11.70's .The scoop is a bit shorter than i would think is ideal ,but it looks cool and fits the 60's theme on this dart .More changes are coming ,and thanks again for the good advise ...
