Performance and Race Parts
DART5770
Albert Lea, MN
FOR SALE:
Hooker #5204 A & F body Small Block headers 1-3/4" tube, coated(early type, not Jet-Hot) $200.
Polished Edelbrock Performer intake manifold, 318-360, from street-rod. $125.
Pair Cragar Super Tricks - rears - 15" x 13", 6-1/2" back space, 4-1/2"-4-3/4" bolt circle. Drilled for screws. $250
Milodon #30940 center sump deep pan for small block 360 with pick-up. 8qts + filter. $125
NEW Speed-Pro R9278+.035". File fit, plasma moly ring set. 4.350" bore. 1/16 x 1/16 x 3/16 with low tension oil rings. $90. (summit @ $123)
New Moroso solid motor mounts for B,C & E bodies for all V8s except hemis. Part #62520. $25
MSD 7AL-2 Gold Ignition box, utilizes chips for rev limiter. Carried as spare for years. Just bench tested-works good. Going to hemi controller- don't need anymore. $250
MSD 8251 HVC coil for 7 series ignitions. $75
MSD 8739 2-step module. Fits above box and others. $40. Buy 7AL-2 and coil & will throw in the 2-step.
New Sealed-Power BB Mopar High-Volume oil pump #224-4146V. Still in the box. $50
Edelbrock SP2P Intake manifold for 318 small block. $80
Take-off 3.9 liter V-6 stock valve covers from 1991 - only 10K miles. $5
New Mopar Performance P4120459 1/2" head bolt washer kit. $10
2.74 first gear/low gear set for 904/999 torque-flite transmissions. Get off the line quicker. $100
New Rhoads lifters for Mopar V-8 #20118. $75
New 8-3/4" or Dana 60 Axle retaining plates(pr) $5
New Elgin 383-400 moly pushrods for adjustable hydraulic lifters. Cup & Ball ends. 8.300" overall length. $75
Manton RB BB Mopar Pushrods 3/8" heavy wall. Cup & Ball ends for adjustable rockers. Set of 16. 8.710" 'Effective' length or 8.780" overall length. Low runs-like new. $100
New TCI 5.0 ratio Band Apply Lever for 727 & 904 Torque-flite transmissions. $20
RJS Mesh diagonal window net, Used 4 times. SFI expired. $15
S.B. Mopar 273 factory connecting rods. Used in other small blocks for liter weight rods. $80
NEW Manton series 4 heavy wall 8.900" x 3/8" pushrods. Ball/ball ends, hardened tube. Never used. Set of 17. $150 OBO $225 New.
1967 440 Engine block D440 Dated 4-7-67 if someone needs a correct date coded block for a restoration. $500. Heads and intake also available.
Brand NEW 1996 Dodge Dakota truck frame. **BARE** For 2 wheel drive short box. Cut off at rear axle...have rear section(approx 3ft). You Haul! Want rack and pinion & A-arms on a street rod? $50
SB Mopar Adjustable Pushrods for hydraulic lifter and stock type rocker - Ball ends. 15 good...1 Bad. $50
1967 GTX & B-body 26" radiator with original fan shroud. Nice! Been out of car since 1972. #2785936, tested. $599
1990's 318 Throttle Body Injector with 2 extra sets of injectors - some New Holley injectors plus extra gaskets, sensors etc. $50
Family Software 'EGT' Kit - Exhaust Gas Temps with single exhaust probe and digital readout module. $100
TRW Forged 340+.030" (4.070" bore) 12.5 compression domed pistons. Litened and gas ported. 1/16" rings. Takes .990" BBC wrist pins (not included). SBM is .984" pins. BBC pins have more available wall thickness & lengths. (Almost $500 in litening, gas porting and boring wrist pin holes. $150 or make an offer/trade.
NEW Flowtech Headers for Big Block Dodge trucks. 67-82 383-440 1/2 & 3/4 ton pickup or 74-78 Ramcharger. #13504 , 1-3/4" tubes. In the box.
$150
Used Mopar Performance mini starter. Worked great when removed. $80
PM for more pix or info. Thanks.
if moparfan do not want the oil pan I signed. Did you send to Argentina? Thanks
MSD 7AL-2 and two step SOLD.
Sorry, Will try to get more pix up when I can figure out to resize some more.
I'm interested in the RB push rods and the 2 step. shoot me a pm with shipping to 20601
More pics.
By New 8-3/4" or Dana 60 Axle retaining plates do you mean the shock mount plates that the U-bolts go through? If so I would like to get them.
Kenny
pm me for email to send pics to
More pics
Thanks for all the responses. Yes this ad is old but still have some things left.
MSD 8739 2-step module. $35
New Rhoads lifters for Mopar V-8 #20118. $75 Sale pending
New 8-3/4" or Dana 60 Axle retaining plates(pr) $5 For 'Green' type ball bearing.
New TCI 5.0 ratio Band Apply Lever for 727 & 904 Torque-flite transmissions. $20 One left.
S.B. Mopar 273 factory connecting rods. Used in other small blocks for lighter weight rods. $80
Brand NEW 1996 Dodge Dakota truck frame. **BARE** For 2 wheel drive short box. Cut off at rear axle...have rear section(approx 3ft). You Haul! Want rack and pinion & A-arms on a street rod? $50 **What do you have to trade??**
TRW Forged 340+.030" (4.070" bore) 12.5 compression domed pistons. Litened and gas ported. 1/16" rings. Takes .990" BBC wrist pins (not included). SBM is .984" pins, hone your rods .006". BBC pins have more available wall thickness & lengths. (Almost $500 in litening, gas porting and boring wrist pin holes.) $125 or make an offer/trade.
Also have some 833 4 speed parts. 1966 or 67 main case, 307 bearing and tail housing. Cluster gear and some misc.
Thanks FABO!
