DART5770
FOR SALE:
*Mopar Performance Small block dual-plane intake manifold 318-340-360, Holley flange. Used very little. $150 + shipping.
*NEW MSD 7561 Programmable Launch Rev Limiter-RPM Controller. Never been installed. Must be used with MSD box that has plug-in chips 6AL, 7AL-2 or 3. Comes with complete instructions + software disc for PC or Laptop programming. Can also program with MSD #7550 hand-held programmer(see below). See msd.com for a copy of instructions. This is not leagal in some classes of racing (considered traction control and therefore no longer available) $200 + shipping
*NEW MSD #7550 hand held Programmer/Monitor. Can be used for programming above box and many others including MSD Gen III hemi ignition system. $200 + shipping
Can do a package on 7561 & 7550 for $350.
*Fluidampr for internal balance Small Block Mopar 318-340. SFI approved. With instructions. $250 + shipping
*Direct Connection- Mopar Chassis Book P4349341. 1984 printing. Like new. $15 + shipping
*MSD 8738 Soft touch Rev Control for MSD 6T, 6TN or 6-HVC ignition boxes only. Has direct plug connector instead of individual wiring. $50 + shipping
*Moroso U-Joint girdles for 8-3/4" rear. $10 + shipping.
*MSD Pro-Power II ignition coil #8220. (number has been discontinued) $30 + shipping
*NEW Direct Connection Steel Shim head gaskets for small block Mopar P4120094. Gaskets are .024" thick and are no longer available. This same number is now a composition gasket at .040+". $40 + shipping
*MSD #8950 RPM Activated Switch with instructions and 3000 test chip. $40 + shipping
*NEW Mopar Performance small block A engine Rocker Shaft Hold-down Kit #P5249712. Blue anodized billet aluminum blocks with ARP 12 point bolts and washers. $90 + shipping
*(2) Mopar Performance Constant Output Voltage Regulators P3690732. Holds to constant 13.5 volts, FOR RACE ONLY. Fits 1969 and OLDER Mopar charging systems. $12 each + shipping
Can PM more pix of items for serious buyers.
Thanks FABO!
Thanks FABO!
