Jkastelein
Hey guys I got a 340 with and m-1 intake and thinking about swapping for a preformer rpm what do u guys think..? Will I gain more out of the rpm?! Thanks.
If that M-1 is the single plane, then yes I say swap it. the RPM will give you better low end with those gears.
I also was going to swap the gears for 4:10's... And yes it's the single plane.
Yes keep the M1, and switch to a 750dp and add converter.
Now yer talkin..........Single all the way and maybe a "Thumperized" carb to boot...........:burnout:
No way, not on a 340 with that camshaft. Ain't gonna have the legs to make that m1 work. An Ede Air Gap will mudhole the M1. BTDT, along with many others, got the t-shirt.
