SheSaid
Mopar/Jeep Guy
So I am in an ignition quandary and was looking for some FABO knowledge.
I am in the process of putting together a 1969 340 stock stroke motor. I am shooting for 400-450 hp that I can spin at 7k and make it look as stock as possible. I have do not have unlimited funds so I am looking to save when I can.
I do not have the original dual point cast distributor. This was my late fathers first car he bought in 76 so I may find the original dizzy but as of right now it is MIA.
Option #1
Stock single point distributor plus Pertronix Ignitor III and coil with Mr. Gasket re curving springs.
+ I could do the whole set up for a little over $200.
+ Eliminates points.
+ Stock Appearance
+ Rev Limiter
+ No More Ballast
- Quality of stock distributor
- Appearance is not quite the same as the original dual point unit
- Chance the mechanical curve might not perform as well as aftermarket distributor
Option #2
Mopar Electronic Unit with Chrome box
+ Could piece the system together for slightly less than Pertronix route
+ Proven performance over 6k rpm
+ Availability
+ Looks typical for a Mopar
- Has a history of overheating
- Still have to use ballast
- 1969 never had the box will not look exactly right
Option #3
Who knows? Fill in the blank Just not a bright red MSD system that costs over $500 that would be too easy.
View attachment 0901phr_14_z+mopar_318_magnum_engine+msd_pro_billet_distributor.jpg
Option #1
+ Stock Appearance
+ Rev Limiter
+ No More Ballast
Option #2
+ Availability
Option #3
