1964 dart two door, originally slant 6 with 904 and 7.25 rear end.
When I got it, it had a rhythmic vibration that became appearant at 45 and intensified as speed increases. More prevalent under load but still there on decel.
Replaced all front suspension parts: no effect.
Replaced tires: no effect.
Replaced axle bearings, engine, transmission, motor mounts, transmission mount, driveshaft.. Still there.
The only thing left original is the saggy leaf springs and rear end...
I have plans to put new springs and an 8.8 rear end in the car, but I'm not there just yet. The reason I mention this is because when I get those parts in I will be setting the pinion angle, and there will be no more original parts left in the drivetrain.
Could those last two things be where all those damned vibes are coming from??
