Have a 340 block ready to assemble. # 0B259831 , FW340P31220183 ,been thru machine shop - bored/honed with plate, align hone mains, resurface, magna-fluxed, cam brgs., tower shaft brg. , 060 over bore with #5 sleeved
Original forged steel crank - #2532457 cut 010/010,
stock rods # 3418645 , floating pins
Heads - set of J heads 202/160 #3418915 or a set of Indy Aeroheads , 202/160 #348915 , new in box from 20+ years ago
Cam/lifters - my own used unidentifiable mech f/t stamped # 931958 with lifters (needs to be measured to know & lifters would be checked) I was happy with this cam
OR
a new in the box cam & lifter set 20 yrs old - Mopar P5007695 cam & Comp lifter set 822-16 - 20 yrs old - these are hyd flat tap
rockers are the 273 adjustables likely 1.5 ratio
intake is LD340 and carb is AVS2 800cfm or I have a 6 pak intake & carbs
Would need pistons/rings & on & on & on - would like to be 10.5:1 ,
Would these bits & pieces work together or would they be terribly mismatched. Or would you sell all this junk & stroke the thing like I did the last ?
OR
