mopar part# 53008180AB. it fits where the hub of the converter sat in, has a roller bearing insert, fits almost all mopar cranks from slant 6 to big blocks. its also cheap too--currently lists at 12.95 at your local dealer.
if you buy this bearing--you can drill the end of the crank by hand without worry of being accurate. just drill untill your up to approxametly the second knuckle on your index finger, hammer the bearing in, and your done. dont cut the shaft on the trans---its bad for possible re-sale in the future.
--chad
