AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,724
- Reaction score
- 12,091
As long as the ONE clip is not interfering, and the other clip is fully engaged and the saddles are on the fork; it might be OK: but
>those clips are what keep the TO bearing attached to the fork so that when the fork retracts, then so does the bearing. >Furthermore; the clips keep the saddles of the Assembly on the fork, which keeps it from spinning.
>Furthermore; if the TO assembly spins with the fork retracted, chances are very poor that the saddles will ever, by itself, re-align with the fork.
IMO
the bent clip should be replaced. There is a slim chance you can can do it with the trans installed; I think I did it once, working thru the bottom and the Fork-window.
IMO
