72ScampTramp
Scamp Tramp
Rear Suspension is SS springs, CE shocks. Dana 60. Ive read many write ups and all them are different including the tech pages on BBD. I imagin I need to set pinion angle before measuring driveshaft length correct? What should pinion angle be?
Also I have a 440, 727 and Dana 60. If ive read right i put the yoke in the rear of the trans and slide all the way in then pull out 1" then measure from the center of the yoke to the center of the rear yoke is that correct?
