just put a new rear in my car and setting the pinion angle to find out it is 8* cal vert racing recommends -2 to -4 for there set up so by my math I had 8 on the pinion and 0 on the driveshaft, so by my measurements if I got a 6* shim it should be 2 on pinion and 6 on shaft which would equal -4 does this sound rightand is a 6 degree shim to thick :blob:
