3404spdfish
ok so I am almost done with the spring relocation in the 65 barracuda gift to my brother. at the beginning with the 7.25 still in the car I measure its pinion angle with no weight, it had a 5.5 negative angle, it has SS spring in it. would be correct to set the 8.75 narrow rear end in car and set it up with the 5.5 negative angle again? i am not sure how to set the angle with a new rear end with un welded purches with no weight on springs. the 5.5 angle i started with was with u bolts in and torqued on the 7.25
