Pinion seal
DAN1234
Active Member
long island
Hello folks maybe someone could help me out,just bought a pretty clean 72 Duster 340 that has a 8 3/4 rear that has a leak from the pinion seal.Went to replace the seal,marked everything only to find out that the nut that holds the yolk on, was on not even hand tight.Any one have any ideas on how to get this back together correctly?thanks
Do you know what carrier you have 741 or 742 or 489.
741 and 742 uses a solid spacer and shims to set pinion bearing preload, not considering any damage done from being loose, you can just remove the nut/yolk install new seal with some sealer around the outside,reinstall yoke recommend a new pinion nut and torque to over 240ftlbs,
489 uses a crush sleeve that is single use only and you need to slowly tighten the pinion nut while measing the torque it takes to turn JUST the pinion, so you have to remove the carrier and remove the ring gear, intall new crush sleeve and seal, tighten gradually until you get the right turning torque for the pinion, then reinstall/set up the ringgear. Not easy but can be done with dial indicator,12" spanner wrench,gear marking compound,
The pinion bearings are probably trash having been run with little or no pre load so it most likely needs to be pulled apart no matter which carrier you have. The numbers are on the bottom of the of the carrier left side near the yoke They are cast into the carrier
Thanks for the advice.I forgot to mention that it is a 489 carrier so I put the seal in and ran it down pretty tight with a gun.Went for a ride no leaks no noise hope it works out again thanks for your help.
