68 Coronet RT
68 GTS # 508 in Registry
I'm looking to replace the 3.23 gears with a set of 3.91 Richmond Gears but they list 2 different pinion splines. One is a 10 spline and the other is a 29 spline. It will be going into a 68 340 automatic GTS. So without tearing it apart how can I find out which spline it is so I can order the gears. Thanks for any input !
