Pipe dope on my temperature sending unit. Is this okay?
cruiser
Bloomington, MN
Hi All: The guy who rebuilt my cylinder head installed the brass temperature sending unit into the head with what looks like white pipe dope sealer. Is this correct, or will pipe dope on the sender interfere with the signal that it sends to the temperature gauge in the dash? I thought I read somewhere that these senders should be threaded directly into the head to create a good brass-to-iron connection. My FSM doesn't address this issue. Whaddya think?
Easiest way to tell is to put an ohm meter on it, one probe on the body of the sensor and the other at a good ground on the engine block.
No resistance= good to go, no continuity= remove, clean off, and try again.
If I put any thread sealant on at all I just apply a little bit. It's tapered pipe thread and unless you leave it loose, it won't leak.
No. It might or might not completely block the electrical connection needed between the sender and the head, but it's not at all needed or beneficial. It's brass; it's not going to seize; number one. Number two, those are dryseal threads, designed to create a leak-free seal when assembled dry/without any other materials. Remove the sender, clean it all the way up, and reinstall it dry.
As the old commercial used to say, "a little dab will do you". I put a small dot on the base of the threads and spin it to distribute the thread sealer. I've been doing this for decades and have never had a problem.
The threads will exert so much pressure against each other that there WILL be metal on metal contact
People put dielectric grease (which is an insulator) on terminal contacts all the time and there is still metal in metal contact.
Dryseal threads are not quite the same thing as NPT. Related, similar, compatible, but not the same.
Who said anything about dryseal threads? I don't care if it's a water pipe or a natural gas line. NPT gets some thread sealant or dope pending the liquid involved, just like the temperature sender gets going into a cast water pump housing.
I always put SOME kinda sealer on NPT threads, regardless of application. Always have.
There's some great sealer on the market these days.......I've used Teflon tape since I was old enough to drive.
