1970 dart swinger. Stock hood. 5.9 magnum 408 stroker, air gap intake I don't have a carb yet, spool mount k member. Will it all fit under the factory hood?
Not sure, but I had the same problem and moved my battery to the trunk (passenger side) and used a carb hat to a fresh air location..where the battery was. Bump back to the top for you
to find a tech that has dun this
340(372)with Airgap/750 Holley with dual snorkle air breather fits in my 73 Dart Sport 340.Maybe its the air breather base that helps it fit? View attachment car 015.jpg
