fishy68
Tyr Fryr's Inc.
Hi Guys, one more question:
i read in the book "how to build big inch stroker SB´s" that the Pistons (for example the KB 356) will stick out of the deck a little and will require machining to clear a closed chamber head. This build was with a block that was not the standard deck height, but i calculated his measurements with my block and think the same will happen with my production 360 block. Did anybody use the KB 356 or IC 745 Pistons in a similar build and can tell me if it´s true that the pistons stick out of the hole? Want to use magnum heads, dont want to run into trouble, machining the pistons will require new balancing........can you help me again???
regards Michael
Can't say anything about them sticking out of the hole but if they do you should be able to run a thicker Cometic gasket that'll give you the clearance needed. That'd be cheaper than machine work and easier too.
