It also isn't as easy as just airbrushing on a coating and baking it in your toaster oven.
Each type of coating has its specific application requirements. Every part has to be media blasted before coating-and different coatings call for different blasting media. Also, some parts need to be heated prior to coating. Then each type of coating has its own temp range and length of time in the oven before it is finished.
The pistons, for instance, can have up to three types of coatings. Anti-friction for the skirts, thermal barrier for the dome, and oil dispersant for the underside. It's not as easy as it sounds. I have watched them prep and coat the parts at the machine shop, and it is fascinating, but a lengthy process.
