the KBs a rea good way to go for a mixed duty build. But, pay attention to details if you want to run a closed chamber head. When they are in at zero deck, they will protrude .018" out of the block due to the design. (Identical to the older TRW/Speed Pro designs) So you want to make sure you either leave the deck tall, or mill the piston down to get a true zero deck and set your quench with a closed chamber head. If you run iron, don't sweat it. For a step up, I'd run Diamonds, but because you need .040 over, the usual Diamonds/Ross will be a special order and a bit more cash. Anything over .030 over in the higher end pistons ends up being a custom piston with the associated charges.
