joshua dewitt
ok, im confused building a 1st time 318 performance build. been a chevy guy in past, i crossed teh line, hehehehe...
ok i have a 73 virgin 318 block, just a standard polish crank, new eagle rods with arp bolts, new press fit 87-91 318 9:1 flat top pistions( all flat, no reliefes) seam to be all like that, afer assemble, close to a near zero deck ... just under, .0190"
now i found som #302 casting heads allready rebuild, set them on with ath the old head gasket @ .035" all ready comrpresed... and some modeling clay on pistion... using the mopar performance 340 resto cam, and matching lifter, went to check clerance, using an old 318 original lifter, i tackwelded solid for moc up, and won"t roate, exhaust valve hits,... using a mechanical lifter,( has a deeper relief in it form parts store,) and valves will barely open? using the new lifters, ( mp 340 matching) with comp cams (stock length) push rods, will spin, but very close and possible draging on top of pistion, don't even have oi pressure holding lifter up yet. has anyone heard of tihs beign a problem? from what i read, the facotry 87-91 pistions are the same as 73 just differant compreiion height, 8.0 to a 9.1... and thease are the heads that are suposed to mate for those years, the rocerks say "91 on them? what gives, any ideas, do i have to get differant pistions with vavle reliefs, or am i missing something here?
