DusterBoy15
THE WISE(guy) MEMBER
how do i take off the pitman arm off from the power steering gear and how do i tighten the main bolt that holds the adapter to the block and what size is that bolt and the main pitman arm bolt???
Well that is an easy one, you will need a pitman arm puller, and most likely a 3/4 impact gun to supply enough torque to remove. The tool you need is in the bottom right of this photo http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92882how do i take off the pitman arm off from the power steering gear
Need a better explanation of what you are talking about hereand how do i tighten the main bolt that holds the adapter to the block
I think the pitman arm nut is 34 or 36 mm.and what size is that bolt and the main pitman arm bolt???
