B.D.A.
going from p.s. to manual ,picked up an early small sector shaft box,but pitman arm faces up ,my power box faces down and its sector shaft is larger, and i can't swap them because they are different sizes,is there one for the small shaft box facing down,does anyone have one? this is a 1973 dart,was 6 cylinder,but installed a v8 70 dodge sport k- frame and lower control arms,so all the rest of steering linkage is 6 cylinder stuff,the manual box is from that dodge sport.which i also have the column for.reason for changing out the k-frame was due to a failed attempt at putting a rack in it ,i cut it up pretty bad,. only took this frame because it was available.i hope this frame is usable with out changing over everything ,how about my 6 cylinder idler arm,once i resolve the steering box problem,i have already purchased schumacher mounts for this style frame with the flat surface where mounts sit,and have the 440 bolted in.i have a center sump pan to go on ,right now it has a rear sump and i will need a pick-up tube, or maybe i'll modify it , but don't have the pan off yet to see whats involved.
