**planning ladder bar set up**
Mopardude318
That is a sweet set up looks awesome!
Please check your PM's and get back to me when you can.
Thanks
I'm not exactly sure what your asking, but the tabs that are welded to the axle for the lower link bars that go into the spring relocation? Those tabs were made by Bill, but can be easily made...
Check out suicidedoors.com they have build your own 4 link kits that run the gamit as far as options and they are anywhere from $299 to $899 depending on what you want and then all you will need to do is fab the shock mount and front upper control arm mount out of tube steel.
I'm not exactly sure what your asking, but the tabs that are welded to the axle for the lower link bars that go into the spring relocation? Those tabs were made by Bill, but can be easily made...[/QUOTe
I am talking about where you moved the front perch on frame rail. Those new perches, did you make them?
Does anyone have a link/plans for building a 4 link from scratch,same idea as the caltrac link?
That would be a great thing to have. I most likely will be building my own Triangulated 4 link set up or I should say piecing it together....
Thanks JOHNPARTS for posting the link to SUICIDEDOORS.COM , I will be calling them for their kit as soon as I get the measurements for the link bars. I will be using their 1.5" Tube set up with adjustable rod ends on both sides of the link so I will be able to loosen the lock nuts and just twist the bars for a quick adjustment. Their ROD ends are 1 1/8th in thickness, pretty beefy and they offer different types of bushings etc.......pretty cool stuff! For the do it yourselfer you can get into one of these systems for around $750.00 with really nice 2 way adjustable coil over shocks. Of course your LABOR OF LOVE has a price on it also!! Time=Money right?
I'll be biulding a set up for my dart soon as well. I'll be doing a home made 4 link with air bags. Pretty much the same set up you see under lincolns and such. It's going to be a cruiser, no track time.
good thread...keep the pics coming.
Happy to share and we will have matching rear suspensions as soon as I get my body work done.
