hemitheus
19? Plymouth Scampenstein
Does anyone repop the little plastic bushings that go on the arms that connect the wiper pivots to eachother and to the wiper motor under the dash?
Your local Dodge dealer also has them there are 2 different ones You need 3 of the small hole ones and 1 of the large hole to do all the linkage. I have found that the aftermarket only sells the small ones.
Brian
I've had problems with the aftermarket bushings. The plastic is too hard and is a pain to snap into place. The O.E. ones are easier to install.
