AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,622
- Reaction score
- 13,860
Forget the acceleration rates for the TC selection; that is a different matter entirely, and is a side discussion to what you want. Use what was summarized in post #12.
As for the best shift point, it depends more on how the torque drops off below the data presented in your dyno sheet. If the RPM's dropped from 5400 to 3200 RPM on a 1-2 shift for a 904, then what is the torque at 3200? Can't tell from the data... IMHO, for drag racing, you would upshift at the point where the after-shift torque is roughly equal to the pre-shift torque... i.e, you evenly 'straddle' the torque peak before and after the shift. (And I can see it varying from there but that's 'in the ballpark'.)
I've been preaching something like that for years, except straddling the power peak and that's why I rebdachit out of my combo. And maybe why it goes 93 in the 1/8th. IDK, I just like the sweet sound of 8 little KB107s flailing about in brotherhood with screaming pipes, at 7000. I could care less if it might go quicker or faster,shifting earlier; I ain't pulling the stick 'til I get my fix!,lol.
That's also why I don't do automatics, the TFsplits (.59-.69) are quite wide, and it's easy to fall off the cam. If you don't have the TM or pressure, there you are waiting for something to happen. The 2-3 ain't so bad, but the engine still needs a heck of a powerband; about 2000rpm. My combo is only 1250/1350ish. I'm thinking of getting something like a 282/288/100 tight-lash solid next go-round... hyup ~195psi/~181VP and Caltracks should do it.
Quick; how fast will it go,lol. I don't care,obviously, 181VP is only good for one thing; showing off. I mean that's supercharged 408 territory.
