There's LOTS of room for error, here
YOU REPLACED the coil? What coil? What brand and specific model? If it's an Accel, it might just need a special resistor, some of them need the OEM resistor PLUS the Accel resistor
WHAT are you running for an electronic ignition? Mopar ECU? 2 or 4 wire resistor?
YOU MIGHT be losing voltage through the bulkhead connector
You have TWO separate circuits for the ignition
1---The DARK BLUE "run circuit"--- coming from the IGN switch is hot ONLY in run, comes out the bulkhead, and supplies the alternator field, the regulator, and the ignition system.
TO SEE if that is OK, turn the key to "run" engine OFF. Find the dark blue coming out of the bulkhead to the coil resistor and put your meter between that and battery POSITIVE. You will be measuring "voltage drop" in the harness, and are looking for a VERY LOW reading, NOT MORE than .2-.3V (two TENTHS of a volt)
2--The BROWN bypass circuit--To check the resistor (starting) bypass circuit, put your meter on battery positive, and the coil + terminal, and crank the engine USING THE KEY. You should read NO MORE than 1/2 volt
IF the above tests are OK you are getting good voltage for start and run.
Remove the distributor connector (just because) and work it in/ out several times to "scrub" the terminals clean, and "feel" for a good tight fit. Now do the same with the ECU connector.
Also, check the voltage right at the battery while cranking. You need a MINIMUM of 10.5V If less, the battery is old, or discharged, not big enough, or the starter is dragging.
I'm going to REPEAT we need to know SPECIFICALLY what do you have for coil (brand, model) for ECU (Mopar, MSD, ??) and 2 or 4 wire coil resistor?
