superdart
Shade Tree Tinker Gnome.....
This is sort of hypothetical. I currently have a 350-ish hp 360 in my car. It was a budget build with largely stock/used parts. I will not get in to details since it's not the focus of this post. My question is, if something were to happen to it (go boom) what would everyone build?
Keep in mind my purpose is a fun road car...350-400hp max...nothing more. It is not a race car will probably only ever see the strip to see what she'll do.
I currently have a standard bore 318 block (1985 casting) and a set of 302 casting heads. Also, I have a NIB MP forged 3.55" stroker crank for a 318.
The current installed 360 is already .30 over and has 596 heads with a very mild port and polish, slightly stiffer springs and some low buck ($180) roller rockers. Assume everything will need to be machine/reworked for a build to keep things even.
The options:
1) Build the 318 using the 302 heads to hit my target hp stated above.
2) Build a 346 stroker using the 318 block, MP crank, and heads off the 360.
3) Get another 360 and build that.
Option 2 seems like the obvious choice from an "already have parts" perspective. Except I would need to do extra machining on the heads and intake to make it work, and considering the target HP, would be a waste, as might Option 3.
Am I missing anything? Vote Away!!!!!
The options:
