rkite
Is there any benefit to running a ported Edelbrock or ported stock heads with 2.02/1.6 valves on a mild cam? Assume a cam with decent lift say .525/.525 262/270 112 or 114 lsa, Edelbrock dual plane rpm intake 650 - 750 cfm carb, 318 or 360.
Wondering if more flow will help on a smooth idling street cam with decent vacuum? Would the idle and vacuum suffer? Would low end torque still be sufficient?
