dustoff440
The thermoquad I have is off of a lean burn 400. It has no ported vacuum for the vacuum advance. This is for a mild 360 Magnum(stock except for 340 exhaust manifolds, a knock off air gap, a small cam Intake 276 exhaust 286, Intake lift 496 Exhaust 512 Intake 112 centerline.
I went with more duration and lift on the exhaust as I have stocker exhaust manifolds and also at one point am going to put a 150 shot of giggle gas.I will be running a slant 6 converter (around 1900 stall) and 3.23's.
My question are there any advantages/disadvantages to running straight vacuum off of the intake manifold? I know that at wide open throttle there will be no vacuum pulling on the plunger, but will I have too much advance at partial throttle? I know that I can run it without any vacuum to the plunger but I would like to get as much gas mileage as possible as this will be my daily driver and also am thinking that gas will go to 4-5 bucks a gallon.
