I love yours too ! I want it Do the lights dim, when you turn that behemoth on? lol
No not yet. I have 100 amp service in my shop so if I don’t turn on my compressor, mig welder, tig welder, and flow heads at the same time I should be good. Lol.
A question: Would it be stupid to shorten the guide at least .200”
Ha ha. I don’t translate. I have understood everything so far.Normally, I don't, cause I'm using a lot of spring pressure compared to stock and geometry is compromised.
In your case, however, you could probably get away with it. (mild cam, low spring pressures)
Keep in mind, shortening the guide reduces stability. You could run a tighter clearance, but that is limited. (stick the valve)
There is airflow to be gained though.
I'm sure someone will chime in here. I would be interested in their take too. (I hope all of this translates into Swedish correctly..)
I don’t follow everything here.I run 220 seat 500+ open
I dont like bronze for endurance
So where is the ops grinder and carbide bits? Let's get to the guiding as he goes...
Whoever leads him to water has to buy him the jb weld , low psi cap..and the stop leak!
Springs, in regards to paper thin guide bosses, varies though..I don’t follow everything here.
220 seat (spring pressure ? )
500 + ( cam lift ? )
open ?
endurance ? Isn’t that the same as wear?
I can take a picture of my “arsenal” if you want. Have to wait till tomorrow tho.
Valves springs and everything were shipped today from US. Must have them home before new guides after that grinding begins
I think I have it covered
Ok. I think the oval shaped will be good in the bowl blending tho. Future will tell
Government Jobs, the best kind.Couldn´t wait. I know the air grinder is not the slickest but it´s free also the air. We had a much better grinder before someone made it turn in excentric ways.
The electric one is heavy as h..l
I think I have it covered , correct me if I´m wrong
Sometimes I even get paid for doing this , depends how much I do at working time.
View attachment 1715523235 View attachment 1715523236
You're off to a great start !
A variable speed foot control will make that electric easier to use..
I use a pedal that I stole off one of my wife's old sewing machines. It works great.
I actually don´t work for the Government , I work as a maintenence technician in a bakery producing hot dog and hamburger buns. Lots of them.Government Jobs, the best kind.
Foredom makes a nice electric unit. (Motor, cable, hand piece) but you have to get the industrial quality unit.
Ebay is full of the 'jeweler' light duty units, but they have a chuck style hand piece. I would avoid these.
A lot of Chinese copies being made that may be even worse.
Maybe someone on FABO is using one, and likes it..
Personally, I would get one with a 1/4" collet style hand piece and 1/4 hp.
I have a similar unit by Dremel for the last 20 yrs or so. Still going. (No longer produced, unfortunately)
Yeah! that's the way to do it
I never liked the sound of a compressor pounding in the background. Can't hear the radio!
(spent my career around compressors, you'd think I'd get used to it.. but I always couldn't wait for it to shut off)
Don't ask my why but I have three of them. I thought the motors would be more fragile so I kept my eyes open and when I saw the higher out put motors for the right price I bought them for spares. Heck I finally changes out my first set of brushes. I do keep a few extra cables around as I have changed out some of those.
