Possible to put a Engine in with transmission in a 67 Dodge Dart?
Small Block Mopar Engine
  1. 67DodgeDart360
    67DodgeDart360 Well-Known Member
    348
    71
    Nov 8, 2015
    Maryland
    Local Time:
    2:02 AM
    Can I put my Engine in with my transmission on in a 67 Dodge Dart? I have a 360 engine with a 727 transmission. I remember I tried before and I was unsuccessful. I know it would be so much easier to put them in together. Let me know your thoughts? Thanks
  2. Blind Squirrel
    Blind Squirrel Well-Known Member
    1,091
    1010
    Oct 1, 2015
    Pacific NW
    Local Time:
    2:02 AM
    Yup, load the trunk with weight to counter balance the front end. Unbolt the k member, lift the front end with a hoist and slide it out. Clean up and paint everything you want. Mount the engine to the k member place the tail shaft on a cart, slider her all back in. Not quite as easy as I make it sound. But that's the way to go.
    Some have also suggested removing the front seat. I have not had to do that.
    • Like Like x 1
    • RAT ROD AL
      RAT ROD AL I know just enough to be dangerous FABO Gold Member
      5,323
      6082
      Jan 18, 2013
      St. James City. FL.
      Local Time:
      3:02 AM
      It will all drop thru the top in one piece. Remove the hood.
      • Agree Agree x 3
      • Like Like x 2
      • pomonamissel
        pomonamissel Well-Known Member
        1,989
        1056
        May 21, 2015
        san jose , ca
        Local Time:
        2:02 AM
        with the hood on , did my 69 gt 383 auto , steering and brakes out of the way on the way in . of course its in n out the bottom , as chrysler did it DSC00280.JPG DSC00281.JPG DSC00282.JPG DSC00283.JPG .
        • Like Like x 2
        • Professor Fate
          Professor Fate Push the button, Max...
          1,944
          2483
          Jan 13, 2020
          Wisconsin
          Local Time:
          2:02 AM
          Sure. Basically, the rest of the engine bay needs to be empty; no radiator, a/c & ps out of the way. Headers may or may not need to be out, depending on who's you're using. Pull the distributor, there's a good chance you'll hit the firewall with it in. No ex. manifolds until it's in. A leveler on the cherry picker helps, but is not mandatory. Drop it into the bay tailshaft down, as the tailshaft nears the floor level it out and slide it the rest of the way back. Set the mounts down onto the saddles, put a floor jack under the tailshaft and level out the engine/trans. Bolt in your crossmember and you're done. Start hooking stuff up.
          Guys will say to put it in from the bottom, but I'm assuming you still have all the suspension/steering still in the car.
          • Like Like x 1
          • Agree Agree x 1
          • dodge71demon
            dodge71demon Well-Known Member
            3,431
            583
            Apr 29, 2009
            Indiana
            Local Time:
            3:02 AM
            • Like Like x 4
            • Slantsix64
              Slantsix64 Well-Known Member
              3,043
              1240
              May 11, 2014
              SGV
              Local Time:
              2:02 AM
              They drop in together just take the hood off, have a buddy sit on the windshield pushing the trans tail down also adjust and mount the chain according. Then bolt the trans cross member first then engine mounts second.
              • Like Like x 1
              • pomonamissel
                1,989
                1056
                May 21, 2015
                san jose , ca
                Local Time:
                2:02 AM
                no need to remove the hood , and one guy can do it all .
                • Like Like x 2
                • mcodecuda
                  mcodecuda Senior Member
                  722
                  304
                  Sep 17, 2007
                  Sherrills Ford NC
                  Local Time:
                  3:02 AM
                  I have put the motor and transmission in through the top of my M code 440 Cuda without removing the hood although I did have to remove the two front hinge bolts.
                  • Like Like x 1
                  • 67DodgeDart360
                    348
                    71
                    Nov 8, 2015
                    Maryland
                    Local Time:
                    2:02 AM
                    Great. I’ll try to put the motor in with transmission next week. I’ll keep everyone posted. Thanks for all information. I appreciate it!
                  • harrisonm
                    harrisonm Well-Known Member
                    3,327
                    3507
                    Jan 16, 2005
                    Topeka, KS
                    Local Time:
                    8:02 AM
                    Yes it can easily be done. Having a second person will make it a lot easier, but you can do it alone. It can be done with the hood on, bit it will be a lot easier with he hood off. I usually lift the front a bit and place on jackstands so I can easily get underneath with a jack to raise the back of the tranny.
                  • A Body 440 WHY NOT
                    A Body 440 WHY NOT Well-Known Member
                    361
                    143
                    Sep 28, 2019
                    Jersey
                    Local Time:
                    12:02 AM
                    Pretty good description. I just did this with a 440/727. What also helps is jack up the back of the car as well. Jack stands under rear. Nose of car lower. Helps the angle It works. Take your time ,
                  • dano
                    dano Evil Handy Man
                    3,895
                    1720
                    Aug 22, 2005
                    Gresham, Oregon
                    Local Time:
                    12:02 AM
                    We did once with a 4 speed. Never again. In and out from under the car, eazy peazy and no beating the snot out of your engine bay. Makes header install short work too.
                  • Fisho
                    Fisho Well-Known Member
                    246
                    128
                    May 11, 2017
                    Barrie, Ontario
                    Local Time:
                    3:02 AM
                    Did it myself, wasn't bad at all
                    • Agree Agree x 1
                    • tanis4457
                      tanis4457 Well-Known Member
                      360
                      101
                      Apr 22, 2015
                      Mountlake Terrace, WA
                      Local Time:
                      12:02 AM
                      Did it myself on my 67 with the hood on, just lower the front of the car by removing the wheels, helps with the angle from hoist. Helps to have a 2nd person if you can so you can stay in one spot.
                      • Like Like x 1
                      • 66fyssh
                        66fyssh Don't Stop Believin' FABO Gold Member
                        6,381
                        5946
                        Jun 22, 2013
                        Northwest GA
                        Local Time:
                        3:02 AM
                        I haven't seen anyone mention it yet but if you're going in from the top, it's a WHOLE lot easier with an engine levelor.
                        Here's one at Harbor Freight but you can get them. Many places.
                        3/4 ton Capacity Heavy Duty Load Leveler
                        Here's me dropping them in a 66 Barracuda together about 7 years ago. IMG_20140807_115151.jpg
                        • Like Like x 2
                        • Agree Agree x 2
                        • mullinax95
                          mullinax95 Well-Known Member
                          11,530
                          404
                          Oct 25, 2006
                          Anderson, SC
                          Local Time:
                          3:02 AM
                          I used a engine leveler with the engine and trans pointed down, with hood removed, and the back end of the car jacked up high as I could get it. Once the trans and engine was going in pretty good I lowered down the rear of the car.
                          • Like Like x 1
                          • 67DodgeDart360
                            348
                            71
                            Nov 8, 2015
                            Maryland
                            Local Time:
                            2:02 AM
                            Thank you!
                            • Like Like x 1
                            • Daves69
                              Daves69 Well-Known Member
                              5,855
                              4259
                              Feb 20, 2011
                              WestOfChi
                              Local Time:
                              2:02 AM
                              Distributor out, and a deep sump oil pan can complicate an assembled engine/trans top install.
