Post/debate your stroker small block builds here
moper
eastern CT
Ok, let's hear what we've all done. I'll list two, with intended usage, the whats and whys, and the costs.
Budget 408: Goals of low cost, low maintenance, 5500 redline, power in the 430hp @ 5000rpm, 500tq @ 3200 range
Machining is where I dont skimp at all. Straight, flat, square, and balanced goes a long way to keeping average parts alive and making good power. So, the base stroker shortblock: clean, sonic test, align hone, square deck, bore, plate hone to ultra smooth finish, clearance for stroker crank/rods, deburr valley and oil drains, enlarge main feeds to 5/16, radius oil passages at filter plate, recon rods, bush pin ends for floating pins if not original, narrow pin ends if not Magnum rods, clean, install cam bearings/block hardware, mockup, assemble complete, degree cam. $2150
Parts: ARP main bolts, rod bolts, head bolts. Eagle cast crank, KBhyper pistons, SP rings, Cleavite/Durabond bearings, Comp cam/lifters/pushrods. Summit timing set, intake manifold, distributor. Edelbrock carb. Melling oil system. MP HP oil pump kit, oil pump drive, fuel pump eccentric, windage tray, rockers and shafts. Airtex fuel pump, water pump. FelPro gasket set. Mr G Tstat, intake gasket, header gaskets, air cleaner assembly. Dorman block hardware. Taylor wires. Autolite plugs. Gates hose. Reuse stock pan, timing cover, valve covers, slinger, dipstick and tube, oil filter housing/adaptor. $2990
heads: reuse any 340/360/Magnum iron castings. Complete go thru with performance in mind. so, guides, exh seats, 2.02-2.08 intakes, 1.65 exh stainless valves, guides trimmed, spring seats cut, gasket match, bowl blend, setup with matched springs, keepers, locks, milled for correct finish. $1200
Total: $6340 complete, air cleaner to full oil pan
Street/strip 416: goals of pump fuel, average maintenance, 6500 redline, power in the 525-600hp, 500-550tq
Machining: same as above minus $150 for using new rods. Possibly add $550 for lifter bore bushings and roller cam lifter clearancing. It's not a secret that good machining is the same on any displacement engine. With roller cam $2550.
Parts:ARP main studs, head bolts. Eagle H beam rods. Diamond forged pistons. C&A rings. King/Cleavite/Durabond bearings. "?" cam/lifters. Smith Bros. pushrods. Summit timing set. Edelbrock intake. Holley carb. Melling oil pump. MP cast crank, HP oil pump kit, oil pump drive, valve covers, timing chain tensioner. Crane rockers and shafts. Milodon pan, pickup, windage tray. Airtex water pump. FelPro gasket set. Mr G Tstat, intake gasket, header gaskets, air cleaner assembly. Dorman block hardware. MSD distributor. Taylor wires. Autolite plugs. Gates hose. Reuse stock timing cover, slinger, dipstick and tube, oil filter housing/adaptor. $5550
Heads: Edelbrock 63cc RPM, heads corrected, cc'd, fitted with matching springs, retainers, locks, ports cleaned up to remove CNC marks, gasket matched, milled with proper finish for gasket type. $2250
Total $10350.00 That again, complete carb to full oil pan, with a solid roller. A flat tappet would be about $9000. Pricing is off the top of my head, and I'll always lean towards the higher figure. I'd rather be high and have you not surprised, then say "$6000" and have all kinds of flailing when it's only the bare longblock for that $$.
"Your results may vary..." flame away! :D
One day Im going to add a 4" crank to my 340. You can never have to much torque on the street !
wow building engines is expensive, this put into perspective of how much stuff costs...dang, sure im not going that radical but wow thats alot
This is my real build - and has been for the most part a very satisfying experience
Initially - streetable 450hp engine to run on 91 octane and put a 68 Dart in the low 12s (goal was 12.12) at local track. (went best 12.10)
Now - streetable 500hp on 91 octane to go 11.8 at local track (3200ft - usually 5000 w/dry air)
388 Stroker
91 360 truck block w/caps
Hot tank, deburr, check bore alignment D&W mach
Sq. deck D&W
Bore and Hone w/ deck plate D&W
Install new cam bearings & frz plugs D&W
Pistons - forged 4.030 Diamond
Rings - Plasma coated Diamond
Rods - Hvy duty Platinum brand 440 source
Crank - 3.79 stroke Billet steel MPP
Modify block for crank to fit D&W
Dampner - SFI Perf. Prod.
Balance Assy R. Derry
Main & rod bearings - radiused HP CL77
Oil pan 8 qt & pu & dp stick Milodon
Oil Pump HV Sealed power
Oil slinger MPP
Windage tray Mopar
Front cover Mopar
Water pmp PS
Studs - Mns &Hd, Bolts & washers Milodon
Gasket set SCE
Head gaskets .040 Cometic
Roller timing set Rollmaster
Fuel pump eccentric - moly MPP
Timing chain tensioner MPP
Oil Pump shaft bushing MPP
Cam - Hydraulic STX-21 Racer Brown
Lifters - anti-pumpup w/snap ring 440 source
Pushrods Crane
Fit piston pins to rods R Derry
Bare heads 596s PP
Valves 202/1625 SS w/11/32 stems Ferrera
b guides, 5 angle, inserts, bowl hog, cut.045 Biltrite
Roller rocker Assy 1.6/1.5 ratio RB
Dbl springs, Cmoly ret & kprs, viton seals REV
Valve covers, pcv, grommets, rubber gskts MPP
Spark Plugs NGK
Intake - RPM Air-gap Edelbrock
Carb - Mighty Demon 750dp BG
Carb gaskets .188 x 2 FBO
1" Super Sucker spacer HVM
Distributor - recurved Ritway
Paint
Wire set 8.5mm MSD
Heads-bowl port, runner cln up, gskt mch Ritway
Assemble complete engine Ritway
May-06 $10120
Credit for iron heads (sold)
Credit for AG intake, RR, p.rods, vl crs
Eddy Magnum hds and AG intake Eddy
Crane 1.6 RRs & m-m prods Crane
Head and intake gaskets Cometic & mpp
replace valves w/ferrera and hone guides Biltrite
ARP hd studs and 12 point nuts ARP
Magnum Vcvrs Mopar
Apr-07 $11670
410" With Procharger
360 Block Bored .040 Over
Mopar Forged 4" Stroker Crank
Diamond 8.3:1 CR Quench Dome Pistons
Eagle H-Beam Rods
Edelbrock Heads Stage II ported By Hughes engines, Commetic Head Gaskets
Hughes Cam Lift .489/.524 Cam, Dur 218/[email protected] Hydrolic, Stock Rockers
Edelbrock Perf RMP Ait Gap intake
Holley 650cfm Carb Modified for Forced injection
Holley Electric Fuel Pump
Aeromotive Bypass Style Fuel Press. Regulator.
TTI Headers with 3" duals
ATI P1SC Supercharger running 10psi
Water/Meth injection Kit
Combination is extremely streetable, CAM profile is design for wide tq band and a streetable Power Band in the RPM range.
On a Dyno jet is made over 500rwtq from 3000-5300rpm
For the nonboost numbers remember this is a low compression engine designed for the supercharger....
Actual Rear Wheel HorsePower
No Boost 310HP/385tq
10psi 520HP@5300RPM/575tq@4000RPM
Flywheel Adjusted Numbers
No boost 375HP/465tq
10psi 625HP/693tq
Old thread, but anybody else want to post their stroker on here? I'm thinking on building one.
AMEN!
This is a good time to add something. I know we have more stroker builds here!
Moper,
what block did you use for the 416?
I have been told many times that the old 340 blocks would self destruct above 500Hp. This is why I have always been looking for a R3 block for the build. My goal is 600Hp. Opinions/experience anyone?
Andrew
For a taget of 600 hp and longevity, I'd look for a R block myself.
I hope this keeps rolling. I'd like to build one myself.
My low buck 410 stroker
360 .040 over
w/torque plates, Cleaned, mag'd, main studs, line honed, square decked w/arp studs=$590
Ohio crankshaft nodular iron 4'' crank kit w/H-beams and KB 356 quench domes, moly rings, clevite rod/main bearings internally balanced=$1300
Free J heads that I ported myself flowing 200 @.300 [email protected] 270'[email protected] 280's@ .530 + Machining-seats on both int/exh, guides 11/32 stainless ferrea/engine pro valves,seals, cc correcting/milling of deck/intake, multi angle VJ,back cutting=$847
Billet timing set,milodon 8 qt pan/pickup package w/melling std oil pump, gaskets, comp push rods, hardened pinned gear intermediate shaft/bushing, engle solid KV3 custom grind .573 lift 282* 252*@.050 110, mopar solid light weight lifters.005 undersize, engle springs, comp 740 retainers with comp +.050 10* keepers for 1.80 installed height=$930
I use bolts off core motors if I need anything like cam thrust plate hardware and even reused a cherry thrust plate.
I'm buying a proform 850 annular for $250 off a guy later this week.
And I'm using an LD340 I paid $90 yrs ago.
Power goal 490-520HP@5800-6200rpm 480-500ftlbs@3800-4400rpm
Grand total $4,007 +/- $200
The factory blocks have thier limits. But, with careful parts choosing, machining, and assembly, the blocks will live at 550 all day long, and around 600 for a while with nothing more than steel caps, main studs, and lighter rods and pistons. But, if someone is planning for a true 600hp, AND CAN AFFORD TO BUILD ONE THAT MAKES THAT POWER, then they should get a new stronger block. For most people, 600hp is a magazine level they want to reach. not a realistic goal for what they can spend.
EDIT: I should add that with the price of the caps, studs, and lifter bore bushings, plus the competition level machining required... you are within about $1000 of a much better block. When the buget is $10K, $1000 more for strength and reliability is nothing.
I built my 408 for the "retro look" in a mostly street driven 72 Demon with a 4-speed and 3:55 rear gears.
443 HP @ 5800 rpm
460 Ft lbs Torq @ 4100 rpm
Carb to pan cost: $6300
LD 340 Intake
Camshaft - Hydraulic Roller (Cam Motion)
Duration Intake: 242
Duration Exhaust: 248
Lift Intake: 570
Lift Exhaust: 562
Lobe Separation: 110
Centerline (Installed): 105.5
Valve Springs: Comp Cams (994-16)
Crankshaft, Cast (Eagle) Internally Balanced Stroke 4.000
Pistons (Wiseco) PN: WISPT036H3
Bore: 4.030
Dish: 20cc
Compression Ratio: 9.9:1
Iron heads; casting # 4448308
Combustion Chamber Volume: 65cc; 2.02" Intake; 1.60" Exhaust
Flow Numbers
Intake Exhaust
0.100 Lift 64 50
0.200 Lift 132 98
0.300 Lift 184 136
0.400 Lift 226 175
0.500 Lift 254 189
0.600 Lift 247 196
Carburetor (Pro Systems Pro Series - XE)
Holley 4150 HP Main Body
Front Jets 78
Accelerator Pump 50 cc
Rear Jets 88
Accelerator Pump 30 cc
Kevco Oil Pan with Stock Oil Pump
Demon 408
Nice combo
Was the base for your motor an 89-92 truck motor?
Are you using stock rockers, push rods, and roller lifters?
Brian
My engine is a very nearly bone-stock, 1998, 360 Magnum that has a mild Hughes cam (214/218 @ .050"), some minimal valve bowl porting and a 3-angle valve job. Stock everything else except for the TTI headers, Air-Gap-style Chinese intake manifold, and a windage tray and M-P distributor.
I added a Vortech supercharger, for 10 pounds of boost. A 750cfm., 4150 Holley dbl. pmpr. supplies 110 octane av gas with an MSD Boost Retard and a Snowperformance BoostCooler alcohol injector spraying pure methanol. starting at 3 pounds of boost.
I haven't run this combination for very long.... I have 3 dyno pulls (445 rw hp/477 rw torque) and 6 runs down a 1,000-ft. drag strip (9.79 @ 106) on it so far with no apparent damage from detonation.
I bought an Eagle, 4", cast crank and a set of I-Beam Eagle rods for it the other day, and, when I can find the money for a set of forged pistons, and some Cometic head gaskets, I'll have a new 402-cubic inch short block to play with. I have plans to add a second Vortech supercharger, blowing into the same carb at that time, for probably, 15 pounds of boost. That should wake it up a little further. The blower setup added 185 rwhp to the 260 rwhp it was making, normally-aspirated. It was pretty weak, because it only had cast iron manifolds and a low-rise intake, to go with that exceedingly mild cam.
My question is this:
What do you think the lifepan of that Chinese Eagle crank and I-beam rods might be, pushing 15 pounds of boost?
Since it made approximately 525 flywheel hp (85-pct. of 525 is 445) with one blower, and a 3.58" stroke, how much of an increase do you think I might see with the 4" crank and a second supercharger blowing 50% more boost (15 pounds vs. 10) into the same carb?
Will it live long enough for me to get it to the dyno???????? LOL!:angry7:
What do you think??????
These are the parts I've collected so far for a 408:78 E-58 ( big deal, right? ) 360 block .030 over, Eddie RPM's ( new in box off ebay from a guy for $1100), Eagle cast 4 ", Scat H-beams w/ 190k ARP's, Probe forged ( 10.3 w/Eddie's), Total Seal gapless rings, ARP Main stud kit, Pro-something Aluminum Roller Rockers, Comp Cams XE285XL cam/lifters, Weiand X-celerator intake, MP Electronic Distributor w/Silver Box, Kevco pan, Melling HV pump, Cloyes Tru-Roller chain, Holley 800 DP(barely used). I've got about $4000 so far and I haven't had any machine work/balancing done yet and need to pick up gaskets and bolts and stuff. PS... the Fortune Cookie that came with my Chinese Crank said " Confucious Say He Who Does Crappy Machine and Assembly Job and Does Not Balance Engine Must Not Blame Chinese Parts!"
68 valiant 408 stroker
71 360 block bored 30 over ,cleaned,magnafluxed,decked,squared,used all studs ARP
4'' mopar forged crank,balanced ,heavy metal plugs
2 bolt main caps stock
H beam rods
KB forged flat top pistons,clevite rings
Charlies 8Qt oil pan
W2 Race heads open chamber ported polished by indy cylinder
Flow# .100 intake 68.7 exhaust 72.5
.200 131.5 119.7
.300 189.8 162.2
.400 246.3 192.2
.500 290.6 211.0
.600 315.9 221.7
Cam racer brown stx-21 Solid flat tappet intake--597" exhaust--.560" (R.A.R-1.6/1.5
duration @-050 intake- duration @-018 intake 306
exhaust- exhaust 306
lobe centerlinein-104 exhaust-108
Schubeck-ceramic coated lifters 220 Lb springs at the seat
Indy single plane -ported to match
Wilson manifold 1" spacer
Crane 1.6 roller rockers
2.08 stainless valves race cut
Pro systems 950 Race carb
aerospace electric fuel pump and filter 375 GPH
1/2" braided fuel line
TTI 1-7/8 ceramic headers -x pipe, TTI 3" exhaust to the back
T-flow mufflers
ATi super dampner
double roller timing chain with tensioner
Mopar electronic distributor-recurved - orange box 8mm wires
'70 340 block bored 30 over,line-honed and decked...
ARP main studs
Mopar 4" cast crank
Eagle sir rods
Diamond flat top pistons 11.7 to 1 comp.
Edelbrocks 65 cc heads,slight port job nothing crazy
ARP head studs
Comp cam roller rockers
Edelbrock air gap gasket-matched
Lunati "voodoo" cam .533/.552 hyd. cam
Quick fuel 850 carb
full msd ignition
tti stepped headers...this combo in my '70 "street" duster,with full interior and the added weight of a 6-point bar went consistent 11.0's @120..through a full exhaust too..cost just under $10k..:-D:-D
>>>"consistent 11.0's @120..through a full exhaust"
That's honkin'... normally aspirated!
I'm impressed! :cheers:
The 340 block is really not as weak as some people think, it was the engine of choice until they started to become extinct in the mid/late 80's you just need to take the correct steps when choosing parts and not take short cuts on the machine work, which is basically the same rules with any build.
I don't have my specifics in front of me but here is a quick run down of my engine.
340 block
Hugues girdle with .005 thousands pre-load
ARP studs.
Eagle 4" crank
Eagle H beam rods
JE pistons w/8.5-1 (nice pistons but they can't read an order form and their customer service sucks)
Comp 578 lift solid roller cam
65 cc Edlebrock heads mildly ported with bigger springs.
Crane gold race roller rockers
BDS 671 over driven 3%
Final comp 12.4-1
Demon 750 blower carbs
MSD ignition
Here's my Junk,
360 block, pump gas, 10.8:1 compression, 410 ci
Eagle 4.00 steel crank, Scat I-beams, Diamond pistons, total seal rings (file fit),
ARP main/head studs, Edelbrock heads stage II ported by Ryan J @ shadydell,
Small solid roller 248/254 duration w/ .576/.582 lift, Airgap (soon to be replaced w/ Victor),
Proform 750 dp (soon to be replaced w/ 950 dp)
Probably around 520 hp, street driven with an 8 inch converter that is a little looser than it should be. All through 3 inch muffs.
Lost track of the cost…but it wasn’t cheap. Still tuning, times are in sig.
Here is the combo I had in my 'Cuda:
360/408
Eagle steel crank,I beam rods,Probe pistons, file fit rings, 10.5:1, zero decked, line bored, torque plate hones, Eddy Magnum heads w/clean-up and gasket match and upgraded springs, Eddy Magnum RPM intake, Holley HP Street 750, Hughes hydraulic roller cam 228 @0.050" (HER2228?), pulled 11" Hg at idle, ARP studs, Comp Promagnum 1.6 rockers, TTI headers, est 460bhp based on Hughes Engines testing, quite docile around town but pretty mean at WOT, never dyno'd or tracked:thumbdow: (sold) I could easily bump the hp up with more cam and some minor porting. Hughes said a bigger cam was pointless without porting.
I didn't add up the cost but remember thinking about $7500??? Cdn. The hydraulic roller cam was costly.
well i'm in the process of doing my 408. i'll list what i have so far to best of my memory. A lot of the things like cam and machine work was taken care of Greg (family friend) at SS/AFX
95 magnum 360
4" eagle steel crank
magnum rods
arp rod bolts
hyd. flat tappet cam
ross pistons
file fit rings
eddy alum mag heads
sfi damper
Not sure how much i truly have in the engine at the moment or will have when its done but i do know that i've spent so far $17,000 on my duster (not including inital cost) to get to the point i'm at now and still have a lot more to go.
