Post your combo
Old combo ran 6 years ago.
Car- 73 Duster
Weight - completely stripped with cage added, all steel. Plexiglass door windows and front windshield.
Gear ratio- 4.31 suregrip
Tire diameter 28.5
RPM through trap- I wanna say around 6200
MPH through traps -115
ET- 11.64
Engine CID 365"
Head Type- j heads
Valve size- 2.02/1.60
Head Work- port match, exhaust ports worked over
Cam Manufacturer- Comp Cams
Cam specs at 50- 244/244
Carb type and size- 750 proform
PV Rating-none
Jet sizes- 86H/86H
Plug number and brand- champion
Intake Manifold Type- Victor 340
Piston Make- kb 107
Compression Ratio- wanna say it was around 10.4
Trans type- 727
Trans Mods- ta rmvb
Convertor type- torco
Convertor stall- 3500
Trans Brake- none
Drive shaft- stock
No idea on the timing been awhile
Rear end type- 8 3/4
New combo. Only pass I made was a second gear launch in front of the house. Blew the tires off. Not sure what it will run. She sure sounds good though.
Car- same
Weight- same with the addition of an S60 rear
Gear ratio- 4.88
Tire diameter-28
Engine CID-371
Head Type-same
Valve size- same
Head Work- full home ported job 255/175@.500
Cam Manufacturer-Bullet
Cam specs at 50-270/274
Carb type and size- same
Plug number and brand- cold ngk
Intake Manifold Type-Victor 340
Piston Make- kb191
Compression Ratio- 12.98-1
Trans type-727
Trans Mods- 5 disc 15 springs front drum, red clutches and bands, 3.8 lever, blocker rod TA rmvb, ultimate sprag, blanket, deep pan.
Convertor type- Dynamic
Convertor stall- 5000
Trans Brake- none
Drive shaft- strange 1350 u jonts
Rear end type- strange s60
An old combo from 1990>
Car 1969 Cuda
Weight 3350@the line
Gear ratio 4.88
Tire diameter 32
RPM through trap 6650
MPH through traps 125
ET 10.71..NA
Engine CID 446
Head Type 906
Valve size 2.14/1.81
Head Work MP template ported
Cam Manufacturer COMP
Cam specs at 50 290/290
Carb type and size 850
PV Rating 2.5
Jet sizes 86/94 no pv
Plug number and brand NGK 7
Intake Manifold Type TEAM G
Piston Make TRW REPLACEMENT 6-PK
Compression Ratio 10.5, actual 9.9
Trans type 727
Trans Mods FMVB
Convertor type A1
Convertor stall 4800
Trans Brake NO
Drive shaft stock or aftermarket STOCK
Initial timing 12
Total timing 37
Total advance at what RPM 2500
Rear end type 8-3/4
  1. Car '69 Roadrunner
    Weight 3800@line
    Gear ratio 4.10
    Tire diameter 29"
    RPM through trap 6200
    MPH through traps 130 best
    ET 10.35 in full street trim and mufflers
    Engine CID 589
    Head Type 572-13 365cnc
    Valve size 2.30./1.88
    Head Work none?
    Cam Manufacturer Herbert
    Cam specs at 50 260/270
    Carb type and size 950HP
    PV Rating 6.5
    Jet sizes 78/84
    Plug number and brand NGK BCP 6ES
    Intake Manifold Type 440-2
    Piston Make can't be bothered to look it up
    Compression Ratio 10:1
    Trans type 727
    Trans Mods race built, low 1st gear.
    Convertor type TCI ProX
    Convertor stall 3600>4200
    Trans Brake no
    Drive shaft stock or aftermarket Dana 60 moser axles truetrac posi
    Initial timing 13
    Total timing 33 deg
    Total advance at what RPM 3000
  2. Dyno'd...695hp from 5500>5900
  3. Max torque 720ftlbs@4400
Car 1972 Dodge Dart
weight 2260, fiberglass front, hood, doors, trunk lid, rear bumper.
gear 5.13 Dana 60, Strange spool, Richmond Pro Gear, Moser axles
Tire diameter 32"
Best ET 10.15 @ 129
Engine CID 383, 360 bored .070
Head type W2 Econo race ported with 2.08 intake. 1.65 exhaust
Competition Cams full roller, @ 50 269, 276.
Custom Trakers crank, 3.685 offset ground, stock 360 main journal size.
Eagle SBC small journal rods, 6" length, 2" journal
Norris 1.6 stainless roller rockers
Edelbrock Victor W2
Holley first generation 1050 Dominator, no PV, 92 primary, 94 secondary
MSD 7AL, MSD crank trigger set to 34 total
727 TF with Turbo Action manual reverse body with brake
Turbo Action 5000 converter
ladder bar rear suspension with old Competition Engineering single adjustable coil overs
OEM front suspension with OLD Race Country shocks
