GMachineDartGT
Senior Member
Thanks Clair!I never get tired of seeing this car!
Rears in 3/4 lips trimmed.what mods to get them to fit? aren't your rear springs moved in 3/4"? any mods to get the fronts on?
Front lips removed entirely. The big brakes in the front change the offset slightly, but the 18" allows me to use a 6.4" backspace. It fits perfectly. I can run tight clearance because the body doesn't roll too much, tires are stiff and the offsets are just right.
assuming you have a mini tub? or Is this the factory rear suspension?1971 Demon
18X10.5 rear 275/35-18 Michelin pilot supersports
18X9.5 front 245/40-18 Michelin pilot supersports
Couple little tweaks with other additions and she will be back on her feet and I will add a few more.
What back spacing/ off set on front and rear?Well I posted here before with my old 14" Magnum 500 set, but now I changed them out for a set of Weld Prostar's(15 rear/14 front) with 245/60/15's in the back and 195/60/14 up front. But now that they are ont he car I'm going to go for a little taller tire up front and then lower it a little to get the stance right. The rears are pretty snug in there too. But I'm very happy with the switch.
If memory serve they are 15x8 or 15x7 with a 4.5" backspace in the rear. id have to measure the front when I get back home but they are 14x6's and I cant remember the backspace on those. I have much better pictures of the care since that post.What back spacing/ off set on front and rear?
Post a side pic and rear of your car please. Looks awesome.Currently I have 255/40-18 in the front on mine with 8mm spacers, there is easily room for the 275/35-18 on mine. The lip is rolled on the front and I modified the leading edge of the front fender. The '67-'69 Barracuda fender has a different shape than the Dart. I made a photo garage on the fender mod: 1968 Barracuda Front Fender Modification for 26" Tires
On the rear I currently have 295/40-18. It will easily fit a 325/30-19 and might even clear a 345; I previously had 325/50-15 Drag Radials under the rear with plenty of clearance. Car has mini-tubs and relocated springs. The fender lips are rolled in the rear also.
Here is a link to pictures of the car undergoing chassis mods and paint: 1968 Barracuda Notchback: Paint and Body 2014
That is bad *** man. I LOVE seeing cars like ours fixed up right. I get a lot of crap about mine being a 74 but every time I see a car done right like yours it gives me hope. I'll be ordering wheels for mine here very soon and was trying to find a reference of what size to order.If memory serve they are 15x8 or 15x7 with a 4.5" backspace in the rear. id have to measure the front when I get back home but they are 14x6's and I cant remember the backspace on those. I have much better pictures of the care since that post.
This one is before I switched the front tires.
This is my current setup with the bigger front tires.
I probably shouldn't have jumped the gun but I ordered these today. 338 for all for from SummitIf memory serve they are 15x8 or 15x7 with a 4.5" backspace in the rear. id have to measure the front when I get back home but they are 14x6's and I cant remember the backspace on those. I have much better pictures of the care since that post.
That barracuda is sexy af...
Looking sweet jpar, I was thinking about the black 5-spokes off the cop carsNot a big fan of the big wheels, but $200 for rims and tires ? OK?!
OF A "05" MAGNUM (street first picture - strip second)View attachment 1714827287
Like your setup.....the wheels and tires look good. Wanting that size of Cobra's for my Duster.This is my 73 Duster with a comparison between 14" and 15" wheels. The top pic is 225-60-14 front and 235-60-14 rear, the bottom is my new setup, 215-65-15 front and 255-60-15 rear. The front wheels are 14X7 and the bottom setup is 15X7 front and 15X8 rear.
Thanks for the compliment! I think I stumbled on a winning combo.That ride height is perfect and those wheels fit the car well. 17's are the perfect compromise.
@leechris81 tasteful job
Really just door panels for a 65 dart 4 doorWhat exactly are you looking for ?
You can post on the parts wanted section on this site, and also check the parts for sale section.
Welcome to the site.
And thanks for the welcomeReally just door panels for a 65 dart 4 door
