ir3333
Car sits the way it should and looks good!
SWEET!!67 Fastback
Front:
Cragar Magnum 510
14 x 6, 3.5” back space
BFG Radial TA P205-70-14
Rear:
Cragar Magnum 510
15 x 8, 4.5” back space
BGF Radial TA P245-60-15
View attachment 1715758664 View attachment 1715758665 View attachment 1715758666
Three years wishing, two years planning and I have taken the plunge. And man am I happy with my choice!
American Racing Burnout with small bolt pattern (considered custom).
Fronts are 17x8, 5" backspace, +12mm offset (1/2") 245/45R17 Firestone Firehawks
Rears are 17x9, 5" backspace, 0 offset, 275/40R17 Firestone Firehawks
These are on a stock 8 3/4 rearend, stock Kelsey Hayes Discs, no adjustments to suspension or fender wells. Clearance is good front and back.
Yes, springs in stock location. The spring clamp is within approx. 3/8" of the tire.Springs in stock location?
@Henchman What suspension you running on this? I love the stance.17x7 super speed wheels
205/45/17
235/50/17
Daaaamn...that babies in the dirt.17x7 super speed wheels
205/45/17
235/50/17
I’m liking the flat black! Can we get your specs for the rear? Backspace and suspension mods?My 69 Fastback 440
American Racing VN510 Draft
18x8 235/40/18 front
18x10 275/40/18 rear
Paint job is coming.... someday..
Any color suggestions ?
View attachment 1715799285 View attachment 1715799287 View attachment 1715799288 View attachment 1715799289
My 69 Fastback 440
My 69 Fastback 440
So the wheels are 0 offset so I think the backspacing is something like 4½ in the back and 3½ in the front but don't quote me on that.. the rear is a b body 8¾ shortened to 55½ inches overall with Dr diff axles and front and rear disc brake kits (which I couldn't be happier dealing with him.. all good stuff ) I did move the leaf springs inboard to the frame rail, which was much easier to do than I thought and we'll worth it. On the rear I left the 3in studs with 1in wheel spacers to center the tired in the wheel well, that way if I decide to mini tub in the future I could fit a full 2 more inches in tire width, but would have to switch to 12in wide wheels of course. But we'll see.. these 275s are no match for the 440 and 3:91sI’m liking the flat black! Can we get your specs for the rear? Backspace and suspension mods?
That is right.. thanks for the correction!! been a while since I did all the mathNope, a 10" wheel with zero offset has 5.50" backspacing, and a 8" wheel with zero offset has 4.50" backspacing.
Great looking car. As,for color suggestions, what ever is under the hood now, as long as its not chevy semi-gloss black!My 69 Fastback 440
Thank you, I love the stance too, it looks bad *** in person.
No suspension yet, it’s still in project mode.
That’s the front torsion bolts out and rear leafs removed.
It’s getting 4 link with a 9” soon, just have measure, cut and weld new bearing housings and have moser axles made.
The front will hopefully get drop spindles, if not, I’ll ditch the torsion bars and build some custom arms and use a set of qa1 coilovers I have laying around.
I wish I went with a little wider front tire but I bought the cheapest e bay tires I could just to get an idea of what to run.
I’m glad I went with the 50 series in the rear though.
It’s gorgeous! What color is the car? I want to do my 65 vert in a creamy white like that. But with a tan interior.
