mrdodge69
Ok after chasing down a Crappy spongy brake pedal for too many years & spending Far to much $$$ I am at the end of my rope. It is the power brake set-up in my 69 Dart. Brake pedal is just a sponge, it has been bleed far to many times & there is NO air. I have changed & or replaced or rebuilt every part there is, & my latest purchase was the Willwood master in the pics. I can get the rear brakes to lock up long before the fronts ever will. As you can see in the pics the brake & clutch pedals are NO where near even, but I was told in the past this was "Normal" on P/B cars. Well I hate it as I have NO brake Pressure in the front. The New willwood is a 7/8" bore & a adjustable proportioning valve.
Should I loose the Booster & bolt the master direct to the firewall?
Moparfest is 2 weeks away & a 5 hour drive in a car with questionable brakes is not fun. I have done it to many years & NEED it Fixed!!!
HELP!!! Before it ends up in a new owner's garage.
