midnight340
Recently semi-rebuilt the 340 and added the Lunati solid cam 235/243 @ .50 and .526/.546 lift (Howards EDM lifters) with a stated rpm range of 2400-6600.
So this is a 9:1 motor, iron ported X heads, LD340 intake, 650 AVS2, headers, all MSD ignition, etc. Heads set up with dual springs recommended from Lunati. Carb all dialed in by A/F meter (good numbers from idle to WOT), runs really sweet throughout lower rpms, nice power from 2000 up, feels strong, etc. All my testing was up to 5500 to maybe 6000.
Got a chance to put it on the strip and to my surprise it seemed to fall flat past 5800-6000 though still running fine. Really just leveled off like there was nothing beyond. With the old .458" lift cam it would run past 7,000 easily. This was with my old Edelbrock 750 carb (much worked over.)
So does it just want more carb, or is there anything else that could cause this???
