Rbob
67 Cuda with 73 K-frame/disc brake setup with 273, I have upgraded the front timing cover to 70'a style and aluminum water pump.
Something tells me I will have issues lining up the pulleys and not sure on what brackets to use. Mine came with the federal pump.
The 73+ steering gear /pump is a saginaw from a 6cyl and came with pump only with no brackets.
So what is easiest? Do I need different brackets when switching to aluminum water pump and 70's style front cover?
Maybe its better to go with the saginaw, not sure which way to go.
