dustermaniac
Senior Member
Does anyone have any pictures of the placement of the 3 brackets that go to the power steering. The pump is the round neck (I believe federal) and there is a bracket that bolts to the back of the pump with two nuts and washers, The front has a long bracket with an adjusting slot cut into it to adjust belt tension and this bracket screws to the front of the pump with two 1/4 20 bolts. There is a 3rd triangular shaped bracket thet has the word TOP stamped into it and I am not sure of the orientation of how to connect up these brackets. I tried one way and the pump pulley was about 1/2" off from the crankshaft pulley. I have changed the pump and needed the brackets from the old pump to bolt on to the new pump. I am just not sure of the orientation of where these all bolt up to. I know that they bolt through the water pump bolts but beyond that I need some help. Thanks, - (maniac)
