[FOR SALE] Power steering cap and distributor Gasket
littleredcoffin
keene nh
Cap still vents,needs paint $,Distributor Gasket off 273,sits on block under distributor base $5.Keene NH.US Postal money order only
Just fyi that is a distributor gasket. You have to have it on any point dual point without a o ring to ensure a good ground.
The distributor would ground though the hold down clamp. That "Shim" Is actually a gasket that comes in an engine kit for older Mopar engines before they used the o ring. We still get them in some Kits today. It is metal so the timing could be set without destroying a paper gasket.
