Power steering control valve leaking
Frank Vento
66 Valiant Signet convertible
Bay Area, California
Hello, I bought a 66 valiant signet convertible with a 273 V-8 automatic transmission with power steering about 10 months ago. The return line was hard as a rock and leaking so I replaced both of the power steering hoses. That leak stopped with the control valve that mounts on the steering box started leaking. Bought a o ring kit and stopped that leak. Then the Power steering pump started leaking. Bought an Oring kit for that. It was the O-ring for the reservoir that was leaking. Stop that leak, now the control valve started leaking again. Any advice from my experienced Mopar pals?
Thanks in advance
Frank
@favcoast
Can you tell where on the control valve it's leaking? It maybe that you pinched an "O"ring or maybe the hose fitting is damaged.
Thanks Cudamark, need to take a closer look, was wondering if the aluminum blocks warp? or if I should lay down a thin layer of silicon between the block and box?
I wouldn't use a sealer between the valve and steering gear, but, a real thin layer of RTV might help on the return line fitting. I have seen those get hairline cracks in them, and they also will warp.
I assume you have the stock large hose aluminum fitting for the return line, and the factory fitting for the pressure line that has the 90 degree bend?
