Need to replace my power steering pump(72 dart s/b) how do I identify it? Are they all the same? Thanks
I had to replace mine, rebuild kit didn't stop it from leaking. I have a Federal pump but with a "O" ring fitting. Most of the Federal ones I've seen use a flare fitting. Just to let you know, if you determine yours is a Federal type and you replace it.Need to replace my power steering pump(72 dart s/b) how do I identify it? Are they all the same? Thanks
