440+6scamp
- Joined
- Sep 24, 2009
- Messages
- 134
- Reaction score
- 1
I'm sure this is dicussed on the forum somewhere but I couldn't find it. I used an EZ wiring kit on my car. I have an MSD points distributer. The wiring is simple... coil wire runs from ignition switch to + side of coil. Therefore, I need to hook it to a source from the column that has power when the switch is in the on and start positions. From what I can tell, none of the wires coming from the switch have power in both positions. So, to start the motor I spliced the blue (power in "on" postion) and brown (power in "start" position) together and it started and ran fine. However, I believe the blue wire is what's powering my gauges b/c they're not working now that I have the blue wire disconnected (unless my gauges just don't work). So, I want to leave to coil wire connected to the blue and brown wires and reconnect the blue wire to the fuse box as I originally had. But now that I have the blue and brown spliced together, anything that draws amps from the blue wire will now do so in the on and start positions instead of just the on position. Will this extra draw when cranking hurt? Is there a better way to do this? Sorry for the long post.
