power to manual disc swap.
AdamR
Big Member
Bethel, CT
My 71 Dart has power disc, The booster is bad and me being cheap Im going to switch it to manual. Whats involved ? Just the master and pushrod ?
Hey Adam, I'm doing the reverse-ish in the Duster. I have 4 wheel power drums, looking to disk up front, a mastewr swap is coming. I ordered a power disc master from Auto Zone. Rebuilt unit. $25
Depends on how hard a pedal you like - Power brakes have a different length pushrod (you know that already) and have a different pedal ratio. It takes less pedal movement to provide the same amount of brake pressure on a power assist brake car.
So, if you like a hard pedal, use the existing pedal assembly and replace the master and get a new adjustable push rod.
you really sure all that is less expensive than a new booster???
Hope that helps!
John P.
www.UsCarTool.com
919-855-8200
A new booster is around $300 if I remember correctly. I also dont want to have problems with low vacuum when I build a new motor.
Adam,
A quick check on www.rockauto.com shows A-1 CARDONE Part # 5476206 available for $118.79 - This is a rebuild and return service so you will have to send your existing booster in and then get it back. Only real difference will be in the finish - it will come back painted or bare, not cadmium / zinc plated.
Hope that helps!
