power wire fuel sending unit
bdrut57
galesburg il
hi sending unit problem. checking power wire with test light it flashes, is this right? thanks brian
should be a slow dim pulse better to test w/ voltmeter. you should see it pulse to 5 volts and back to 0 back n forth.
